and those little strokers rev fast!!!i like the 364 deal using a 350 crank and offset grinding the rod journals down to small journal size to 3.562 stroke. Good way to make use of a 350 crank that has a bad rod journal. Lower bearing speed of the small journal rods , should be lighter too. If you have a stock deck block , you might be able to do a slight .005 mill to clean it up and check the deck clearence to see how much a 350 piston is out of the bore. Silvolite tech told me their pistons would be fine with as much as .040 off of the deck without nitrous so it would make for a cheapie stroker but still a stroker.
How is that possible? Is there really that much of a difference in casting one 350 to another?You clearance the block to clear the crank throws. Not all blocks will have to be clearanced. I built one several years ago that needed no clearancing.
As high as your wallet will allow--this thing about certain sizes of small block being able to rev higher than another is nonsense--all mine go 7500, no matter what size stroke. I have a friend with a 439" small block that shifts over 8000.That 391 sounds pretty neat. What can it rev to?
Heads were old ported AFR 220's, 13.9-1 compression, [email protected]/.630 lift roller cam (ancient Crane design) Victor Jr./850 Holley.Do you have any other specifics about the one you built? Heads, cam, Compression
Major differences--I did one that needed NO grinding, and another identical combo that took a LOT of clearancing.Is there really that much of a difference in casting one 350 to another?
QUOTE]
Yup, you just needs heads that can move enough air at 8000 RPM. You heads and cam will determin your RPM range. You put a set of heads that can feed a 350 to 6000+ RPM on a 302 and 7000+ RPM is easy.
I wouldnt be grinding the rod. Block relief is fine, just me, I wouldnt be grinding on the rods. Did you balance it after grinding. I think all engines should be balanced, rotating assembly. I just dont like the idea of grinding the rod. JRI had to grind on the block for rod
Grinding on the rods after balancing would put the crank into over balance which is fine as long as its not under balanced.I wouldnt be grinding the rod. Block relief is fine, just me, I wouldnt be grinding on the rods. Did you balance it after grinding. I think all engines should be balanced, rotating assembly. I just dont like the idea of grinding the rod. JR
