Is the stock clip (inner fenders,frame rails) for a 66/67 the same as 62/65 clip?
62-65's are the same except the 62's need 62 hood hinges. 63-65 are exactly the same. 66-67 will fit each other, but not the early models.
Most of the bolt on parts are the same 64-67. The sheet metal inner fenders and radiator support are different though basically the same just different where they meet outer sheet metal. The frame rails would be the same. The 67 steering box is different in that it has splines to the steering wheel shaft. If you need suspension parts like idler and a-arms it is good donor from 64 up even frame rails.
