Hey Guys, Any of you run ladder bar/coil over shocks with stock frame rails?I have a question. What are the specs on the coil overs that you are running.Extension length, compressed length. I need to know what size to buy.
Thanx,Brandon
Don't waste your time unless you're going to tie the frames together or put a frame in it. If you put any power to it and it hooks, you may have a hard time opening your doors. LOL. Dave
The sub frame connectors are channel through the floor and the 8 point bar ties to the subfame connectors on each. I have the ladder bar crossmember channeled though the subframe and tied into the rocker pannels on each side.
Brandon
That sounds good. I thought you had stock stuff without the connectors. I just did my frame and tied it all together with a S&W 8-point roll bar. Dave
