Stock six th350 trans if idle is st like at 850-1000 engine dies when put in gear if I set idle up 1150 -1200 it won't stall but chirps tires n want s to take off very hard to drive I need advice different stall on torque converter? Is tranny locked up ?? Which way to go I put call into manufacture but got more confused :mad::eek:
Do you have the vacume modulator connected ???? If so, it there a leak ???
Is your kick-down linkage connected properly ???
Modulator connected but kick down is not connected could a modulator leak cause such an annoyance ??
What trans was in it before?
What is the timing set at? Where is the vacuum advance connected to the carb? It sound like you might be on a ported vacuum connection when you need to be on a manifold vacuum connection.
Mmm don't. Know thanks I will check that can't belive a vacume issue would cause so much issue
