1 - 20 of 24 Posts
WHAT LINKAGE CAN I USE IN MY '62 :ragtop: WILL THE '63, '64, LINKAGE WORK? I NEED TO GET THIS OLD STUFF OUT! :rolleyes:
BIG D
you should be able to swap everything out for a "63 - '65 setup maybe a '66 or '67 too
schwabie
You can use the steering linkage (idler arm and bracket and centerlink) from any 63-67 that has the same power, or non-power, option that you have on your 62. You will need to drill a hole in the bottom of the subframe and get a new pitman arm (if it's non-power). You'll also need new inner and outer tie rod ends.
Vendor
If you are looking for the pieces out of a 63'-67' car I have everything you needs sans the replaceable parts (tie rods, bushings, etc.) and will be in Torrance this weekend for a family event. PM if interested and we can meet up.
THANKS GOOD PPL, I'M ON A MISSION NOW! :yes:
ANYBODY GOT A PIC EXACTLY WHERE THE HOLE GOES? :confused:
Banned
i have a couple assemblies here at the house Darnell in case the hook up in Torrance doesn't work out... scheduling, whatever...
i can probably tell ya where the hole is too if ya want... didja need me ta tell ya where ta stick it? :devil:
Make a stencil out of a paper from the subframe from a 63-67 transfer to thin cardboard and center punch your marks glove up face shield on and get to it Mr..
Move it your burning a hole in the ground !!!
I say'd move it MR:D
Banned
LMAO LOL!!! :rotfl:
yer a nut Joe! :yes: :rotfl:
Discussion Starter #14
WELL I GUESS I'M DUE FOR A TRIP UP THATA WAYS! :rolleyes:
GOT A FEW THINGS YOU MAY NEED TOO! DO YOU STILL NEED THE TRUNK PAN?
:confused:
Discussion Starter #15
OH AND JOE! W*T*H.......... :devil:
:cool:
Discussion Starter #18
I think John has got to have a picture of every square inch of a 1st Gen Nova.:yes:
Usually with lines, arrows measurments etc.....
I hope that computer never crashes on you or that you have everything backed up twice!
Banned
between two computer crashes and webshots going under i've lost thousands of images. multiple thousands :( i was fortunate to have the last go around recovered, i just haven't reloaded them yet...haven't yet picked up an external hard drive so i'm still at risk of losing again... all i have left available is the photobucket link in my siggy...
i used to have every square inch documented :p
1 - 20 of 24 Posts
