SO... after a few months i changed the oil in the nova and tried to start 'er up. the starter just clicked, so after some troubleshooting i decided it was a bad starter and i replaced it.
i put the new starter in and check the gap using the metal rod. it's gapped correctly. i go to start the nova with a second optima battery hooked up via jumper cables. the starter just kept clicking.
so, i know it's not a weak battery. the starter is installed good, so that can't be it either.
i checked the cables with a multimeter, connections are good reading a straight up 12.58 volts. the red cable goes straight to the starter, and the negative goes straight to the cylinder head, and a test light shows a good connection as well.
i removed the spark plugs (well, 7 of 8 coz i can't find my low clearance spark plug removal tool) and i put some oil in each cylinder, and it still wouldn't start.
i undid the clutch cooling fan and crankpulley and tried to turn the motor over by hand. it turned as easy as it ever did.
i tried starting it again, the starter just clicks. dang!
so, the electrical should be good, starter seems to be installed ok, and the motor turns just as good as it did the day i rebuilt it.
any ideas, anyone?
any ideas, anyone?
