Charged the battery and have 12.7 initially then 12.5 after the first startup. Then I took a few measurements cold and hot at the battery which is in the trunk.
COLD
With just the fuel pump I get 14.4.
With pump, lights, stereo, and fan I get 14.1
** big drop here is the fan.
When I add the Nitrous heater it drops to 13.2
** I knew this was going to be a problem!
HOT
Same as above
I took the same measurements at the power distribution point in the engine bay and at both sides of my cutoff in the trunk, all had the same measures.
I then ended by checking the battery after I shut it down and it was at 12.5.
the last check I did was to check volts of the ignition wire located at the remote starter, I found it to be 12.2. I don't know enough about electrical to know if that is bad or good.
So the car started fine during this test, still a little slow after hot but it did fire up pretty easily after getting over the first revolution. I probably started it 10-15 times during this test as well just to put it thru it's paces.
I guess what I need to be careful of is the nitrous heater, I knew it was going to be a pig. I only use it to keep the bottle warm since I have a water bath to get the bottle to temp.
With a fully charged battery sitting at 12.7V is good and then the slight drop to 12.5V seems inline as you started the car and depleted it slightly.
If then with the motor restarted and it rose to 14.4V is good and then the slight drop down to 14.1V is still good in my book, the issue I see after this with the drop going down to 13.2V is too low. I like to see at least 1V over the nominal battery voltage. Why I say this, is I think I read about this years ago and it makes sense as if you do not have a high enough input voltage to a lower voltage battery the juice cannot be forced into it. This means if I have a 12.7V battery I like to see at least 13.7V to keep it happy and charge it. Granted we might be splitting hairs here with you having 13.2V which is 0.5V over the nominal voltage, it might be enough as you are skirting on the edge and seeing the results. Some charts online for battery state of charge show a 12.7V battery as being 100% while if it's at 12.5V it might be around 80% but this info might not be tuned to your setup but is seen as a basic chart with limited inputted information.
Now on these voltages, is this with the motor at idle ?. If it is, what happens if the RPM's are slightly increased and then held at a normal higher driving RPM ?. Alternator outputs vary by how fast they are spun and maybe it just might take a slightly higher idle RPM to get the alternator to output an additional 0.5V ?. I know on a test I did on my 68 a while back I was checking how my voltage regulator reacted and tool measurements with the car off, car started at idle, headlights on high beams, and such and I started with 12.6V and with it running and different accessories on or off I always had at least 1V over this. You can also see in the video I put together is right before I started it, the voltage was at 12.6V and then once started at idle, the voltage slowly kept going higher up to around 14.2V which is good and then at a higher highway RPM, the voltage rose to 14.7V which is touching on the edge of a limit of 14.4V I like to see and then after I let the motor return to an idle, the voltage did drop but only down to 13.7V and this is still a volt over than what I started out with being at 12.6V.
If you want to see the tests I did, here is the video:
Another test to try is get some measurements when cold and hot and then go for a drive and then when returned, before you shut it off take some measurements and then with it still running and if the voltage is below 13.7V (1V over your initial 12.7V starting point) is throw a charger on it to raise the voltage back up and give it some time to put juice back into the battery, then shut the motor off, disconnect the charger, and see how it is on a restart.
Also too, maybe go over connections on the main power and ground sides of the starting circuit and charging circuit and give them a quick clean.
Also too, is when you are measuring things are you keeping the ground point of the meter in one spot such as the battery or are you moving it to different points for different tests ?. The reason I'm asking is if you move the ground test point around, you may think you have a supply voltage issue but in fact it may be on the ground side.
