i have a 69 nova with mono leafs in the rear i have purchased a pair of split mono leafs from calvert they sold me some plate or bracket that is susposed to be welded in before the springs are mounted my question what are these plates or brakets for and were do i weld them to thanks
I am running the split mono's and there was no welding needed to install! Post some pics of the brackets so we may be able to help out, if all else fails cal Calvert and talk to there guys, they have great customer service!:yes:
You must have the lowered version, someone mentioned this the other day. There is nothing to weld on my standard height Split-Mono's.
Discussion Starter · #5 ·
i talked to calvert today these shims if you will get welded to the lower spring pad to help clamp the springs in place . thanks for your help
