Hey all! After swapping a SBC 383 stroker into my 4-door '74 Olds Omega, I finally got around to changing the front springs to the correct-for-V8 Nova rate (along with a set of Bilsteins). The car sits a little high in the front, which is fine, as these new springs have zero miles on them and still need to settle.
Here's my question: The car has 90,000 miles on it (total; no rollover). Should I go ahead an replace the rear springs, too? Or does age (and lots of garage sitting) not have the same effect as mileage? If I can leave them, I'd like to just replace the bushings (already have a set) and spend the money on a set of Belltech sway bars (I've heard the bigger front sway bar and actually having a rear one make a huge difference in handling).
Normally, the car sits empty, but occasionally, I'll throw a 32-gallon tank *(and/or travel gear) in the back and hit the road. That sucker weighs a few pounds.
