1 - 20 of 59 Posts
part # 91034439 first off I started cutting my shock towers to get my big block chevy into my 1963 chevy II drag car . CHECK OUT THAT POST HERE https://www.stevesnovasite.com/forums/showthread.php?p=5789803&posted=1#post5789803 after wasting a lot of time and money I got this front end from speedway motors. its pretty much the same as Heidts CX-320-X front end frame but cheaper. I did not buy the complete kit because I am changing the front springs and shocks and also using my current brake setup. so here is day 1 - ******FYI. —— CPP full front frame kit part # (Part# E6267M2-X) is on eBay for $500 with free shipping .... I paid $699 plus $250 shipping. Just saying shop around and you can save ALOT of $$$$ I am still very happy with my choice and have zero regrets.. the CPP front is narrowed for larger front tires IMG_2063.jpg
Appears to be a pretty well built piece. Hopefully it’s just that and all lines right up for you.
1968 Chevy II Nova, Central Arkansas
Should work perfect for your application. Keep us posted on the progress.
more parts coming in
new Speedway Chrome Mustang II Manual Steering Rack & Pinion
Discussion Starter #7 (Edited)
new control arms are here
I got the tubular upper and lower arms off ebay
Procomp
Part Number:
PCE179.1008
I have to say they are beefy , come complete and fit the subframe perfectly
Discussion Starter #12
1963 nova speedway mustang II install
so going big block you cannot use the stock throttle assembly and you have to go cable . so I got the LOKAR BAG-6127 throttle direct fit. note to others, I was in such a rush to put the BBC in that I noticed I should of put this on first now that I cant reach the bolts...lol IMG_2142.jpg
We all have been there at one time or the other!
Discussion Starter #14 (Edited)
more progress
So I bolted the front end on today and I must say it went pretty smooth. I hit it with hammered red paint before the install for a little more protection.
here is what I encounted :
1- cut the steering shaft before the install, I need about 2'' of shaft for the column saver.
2- all frame holes lined up perfect BUT the bottom frame holes were to small for the 7/16 bolts so a minor drilling is needed.
3- upper frame to cowl bars NEED to re-use the factory shims that fell out and hit me on the head during removel of the stock fenderwells and use the plates provided with the kit
4- my deep knotched deep pan fit fine no reason to change
5- I used short moroso solid motor mounts , tried the tall ones but one side didn't line up good
6- I forgot to bolt on the gas pedal again ;(
7- new upper firewall bars have 5 hole but I just used the 3 factory ones, I plan on attaching the bars to my roll cage
8- did you notice I painted the firewall and inside of the fenders black? figured it would show off the front end
Discussion Starter #16
shock setup
So I was going to use a moroso trick coil spring and a 90/10 drag shock but looking on the web I did not see anyone using that setup. since I am going to be mostly drag racing I am going with the QA1 For its adjustability and it says its a drag race coilover shock I am also starting out with the 600lb spring part #QA1 MR301-08600 R Series Mustang II Drag Race Coil-Over System 721MR30108600_L_3ec97af0-1104-48a5-8c82-18151ad3d396.jpg
Discussion Starter #18 (Edited)
moving on
got the rack & pinion , control arms , spindles , drag shocks and coil springs on , no drama here , all fit fine just had to trim the rack rubber bushing on the rack a little everything else fit fine IMG_0449.jpg
Discussion Starter #19
put the small block back in
so I put the small block back in , it has 175 more HP and 150lbs less weight plus the weight I saved on the new front frame IMG_0411.jpg
Discussion Starter #20 (Edited)
speedway part # 91031943 Mustang II Complete 11 In Front Disc Brake Kit, 5 x 4-3/4 GM
sooo I got the speedway brake kit for my new speedway spindles - Speedway Mustang II Stock-Height Steel Spindles
Part # 91034307 - the kit comes with everything you need including the lines . it went on OK , on one side the bearings didn't fit the spindle so I just had to hit it with a file and it fit fine.
read the directions !!!! you have to change the rotor bearing races , they are included , the GM ones are to small by a lot .
sooo you don't need the whole kit , my spindles w/ the new races , and my old calipers were re-used and fit fine.
all you need is the caliper brackets part # 91631913 they are about $90 but here is the kicker - speedway wont sell you just the brackets !! even though they have a part # and a price you cant buy them
its still a good kit and worth the money
and I STILL forgot to put the gas pedal assembly on :eek:(
1 - 20 of 59 Posts
