A number of years ago I replaced the original PG with a TH350 in my 66. Since then the speedo has always indicated more MPH than the car is actually going. Generally 10 mph faster. I've ignored it because I didnt want to mess with the speedo gear. In the last year I've noticed a small leak at the speedo gear/cable connection so I went ahead and pulled the driven gear and its housing (bullet). The drive gear is light tan (probably originally white) and looks like it has 5 teeth, maybe 6. The driven gear is the same color and has 19 teeth. The driven gear is 3/4" dia.
I have 25" diameter tires and a 3.08 rear gear. I found a couple of previous posts so I tried the sites mentioned.
The site http://www.5speedtransmissions.com/calculators.html says that I need a 12 teeth driven gear if the drive gear is 5 tooth and that I need a 15 teeth driven gear if the drive gear is 6 tooth.
http://novaresource.org/speedo.htm says that I need a 17 tooth driven gear and a 7 tooth drive gear.
After all that my question is: Who's right?
And how do I accurately count the drive gear teeth w/o removing the tail shaft housing?
Max
Max
