I have a transmission leak that comes from where the speedometer cable hooks up to the transmission. I took it off and checked to see if the o-ring was bad but it looked fine but i replaced it anyways. I then noticed that the threaded piece that the cable hooks up too is loose. Loose as in it screws in and out. Is this normal?
-Blake
nope there is a seal in there and it wears... yours is wore...... any trans shop worth is kitty litter should have that seal in stock...
When you say the seal are you talking about the oring or is there some other type of seal. Is it hard to get to and replace?
Thanks veno
