Just read article in Hot Rod magazine that stated older leaded gas motors that are running unleaded gas should be running one -two heat range hotter plugs to compensate for the missing lead. I am using pure unleaded which is still available in my area without the ethanol in it. What plugs are you guys with the 194 engines using?
I'D LIKE TO KNOW TOO, I'M ABOUT TO PUT A 250 OUT THERE!
I ran R44xls and R45xls AC Delco for many years in my 194/230/250 Frankenstein engine that came with my Nova. It was also in front of a powerglide and I ran 89 unleaded fuel. I had to of drivin that thing for 200k miles!
Im running the autolite 66's right now which is a cross from the stock ac/delco's i believe, the plugs look a little dark/rich and after reading the article in Hot Rod i think i will go one heat range hotter.
