1 - 13 of 13 Posts
what are the best plug wires out there i need them to not melt to the header like my last set and whats a good way to run them to clean up the engine bay
I like the MSD 8.5, buy a 25ft bulk roll from Summit and save some money. With the terminals and boots you can custom fit the plug wires to your car as well.
any silicone wire is going to melt.. it melting point is around 550 degrees....
you need headers or terminal ends that work properly....
generally SBC take a 90 degree boot, and BBC take 180 to 135 boots...
If your frying 90 degree boots on a SBC then you need to find a header that works!....
IF your frying the wire its self.... you may want to took at your routing plan
I use $20 part store wires and found no difference between those and performance ones, had mallory side winders and they melted, you need short plugs and a decent set of looms and take your time to install. :)
I melted plug wires several times until I got Accel shorty plugs and foil insulation for the boots.
Kev
My car slowed 3/10's going from 10.4 Taylors to 8.5 MSD's; I think the problem is RFI related due to the way some of my wiring is routed--just changing back to the 10.4 coil wire brought my times back to where they were.
I still think Taylor makes one of the best wires on the market, but there are plenty of other good ones out there--just avoid the Accel yellow Super Stock wires if you have a burning issue; they tend to melt as you remove them from their package! I had a set on the junk 350, routed pretty well away from the headers, about 2 houses away from home it developed a miss....wires sagged from the little bit of heat in the engine and drooped so bad they were now laying on the headers and burnt through!
Taylor, MSD, Moroso, and Accel all make good wires as long as you get a spiral wound wire. The carbon "Suppression Core" stuff SUCKS and has an incredible amount of resistance!!
If they get on the headers.....ANY OF THEM WILL MELT!!!!!:yes::rolleyes:
Discussion Starter · #9 ·
educate me what is rfi? and i have the msd 8.5 wires and i really like them i guess i will get shorty plugs and a new set of the wires, what are the boot protecters? and how do you have yours loomed?
sorry for all the questions im a collage kid and dont want to have to keep buying wires
RFI= radio frequency interference
Boot Protectors are generally a fiberglass woven matte that slips over the plug boot...
Headers are the problem.. and the brand.... Headers like mine (headman 65019) I dont need any looms just one zip tie per side.. I have lots of room.... the summit racing header for SBC in the gen 3 cars has lots of room too...
you may have to rout your wires under neath? over top..
are you burning the boots or the wires them selves?
Discussion Starter · #11 ·
number 1 and 2 boot only the rest are fine no damage to the wires but it looks like an octopus is making love to my engine haha
I have the taylor 409 wires. Nice enough. Havent melted them yet, did one of the end though. It was on the header, wrong headers, not the boots problem. But.... I would recommend these wires. They are pretty tough for the heat.
Problems??? Yes.. They are so fat that my pickup for the timing light wouldnt get a solid signal without forcing the clamp around the wire LOL Kinda a ***** really. Was the same for my craftsman and snap-on light, their clamps were designed for a standard wire OD. JR
http://www.taylorvertex.com/Products/pdfs/taylorcatalog6.pdf
I have new Taylor's going on tomorrow.
1 - 13 of 13 Posts
