1 - 3 of 3 Posts
I'm running a msd 3-step and a 6-AL box. I want to run a shift light mounted in the original dash, so after it's mounted I won't have easy access to the back of it. What can I run to control the shift light that will be easy to access for changing shift RPM settings?
I'm running an in-dash tach and quad gauge set up. (No "monster" tach) trying to retain a stock appearing dash set up.
Jeff
I use one of these; it's small--might be able to hide it:
Controlled by one of these in the glovebox, where you can change rpm modules:
I believe what Bowtie is showing you would be the best bet. You can hide the box yet still be able to get to it if needed.
1 - 3 of 3 Posts
