can you run a solid roller on the street or is it too much....you know ...starting and stopping..also waht adout making vacuum....and what size would be good for the street??
it will be an everyday driver....maybe see an 1/8 mile race every now and then. probably a 350 with a 350 turbo. something that sounds really good.i had a 350 in a chevelle with a comp.cam 280 dur.480 lift. it sounded good.thanks for he time!!!!you can run a solid roller but it will make a lot of noise compared to a hyd. roller, for a street car that will see everyday use i would stick with a hydralic cam, wether it be a roller or not...
as far as size, it depends greatly on your intended use and motor size, give me more info....
jon
that comp cam 280-480 is the largest i would consider for EVERYDAY driving .it will be an everyday driver....maybe see an 1/8 mile race every now and then. probably a 350 with a 350 turbo. something that sounds really good.i had a 350 in a chevelle with a comp.cam 280 dur.480 lift. it sounded good.thanks for he time!!!!
9.5:1.....maybe some camel hump heads or something close to them..victor jr intake.....650 holley..full length headers....2500 stall...not sure abou the rear gear though....any suggestions? thanks a bunchwell from the sounds of it you should just stick with a hydralic cam, low maintanence and good performance for the daily driver, something in the range of 210 to 225 degrees of duration @ .050
if you let me know more about the combo you will be running i can get more exact, like, comp ratio, type of heads, intake/carb, headers, converter and rear gear....ect..
jon
Not for nothing, but I used to drive my Nova to High School everyday with the old steel headed 383...Even with the 254*/260* @ .050" 108* LSA solid roller, large single plane manifold, HP750 with no choke, 4.11's, 8" 5000 stall converter, power nothing and single chamber flowmasters with dumps. Yes. Everyday, until it blew up at the track.A daily driver with 9.5 compression, the first thing you need to do is forget about that Victor Jr. intake. With a street type cam and rear gearing, and converter size, your car will be happier and faster, and feel much better driving with a dual plane like a Performer RPM. With the limited air flow of factory heads, you don't need an intake that'll breath at 7000rpm because you'll never rev that high, and torque is what gets the car moving. Dual planes build more low rpm torque. Now, the 650 carb is just about right. As for cam shafts, you really need to decide on the heads and gearing first. If you want a couple suggestions, I'd try this cam:
http://store.summitracing.com/partdetail.asp?part=LUN-60103LK&autoview=sku
With these heads:
http://store.summitracing.com/partd...4294908216+4294840140+400304+115&autoview=sku
A Performer RPM Air-Gap Vortec, with a 3.55/3.73 rear gear and a good 3000 stall converter and you'll have good old fashioned butt puckering performance. ZRemember, if you take these suggsetions you 'll need self aligning rockers and centerbolt valve covers for the Vortec heads. All you'll need for exhaust is a set of 1 5/8 headers and a good 2 1/4 or 2 1/2 in system and you're all set.
I agree. I used to drive my 412cid Pontiac with 11.5 compression, 245/255 solid cam, single plane, 3.5" two chamber Flowmasters, 4500 stall, 4.56 gears, front runners/slicks, trick springs, 90/10's as a daily driver for a while, and I though it was plenty mild enough. I just try to answer questions based off the "general" consensus of a daily driver. Most people who want a daily driver don't want to do the maintenance of a more radical set up. Except for those of us who absolutely love the smell of engine oil, and dirt under your finger nails, who else really wants to adjust valves, check carb tuning, and drive slow on the higway because of the monster gears? I do, but most people don't. Also, I base my answer off of how the question was asked, kinda reading into it a little. Hell, I'd drive a pro stock engine on the street if it won't overheat or load up. If you can put mufflers on it, it's a street engine right?Not for nothing, but I used to drive my Nova to High School everyday with the old steel headed 383...Even with the 254*/260* @ .050" 108* LSA solid roller, large single plane manifold, HP750 with no choke, 4.11's, 8" 5000 stall converter, power nothing and single chamber flowmasters with dumps. Yes. Everyday, until it blew up at the track.
There's no set rules on "streetability" for a daily driver, or any car for that matter...What one considers mild, another considers a full blown racecar...It's all about what you can live with.
the heads will bolt up to an older block pre -1980?A daily driver with 9.5 compression, the first thing you need to do is forget about that Victor Jr. intake. With a street type cam and rear gearing, and converter size, your car will be happier and faster, and feel much better driving with a dual plane like a Performer RPM. With the limited air flow of factory heads, you don't need an intake that'll breath at 7000rpm because you'll never rev that high, and torque is what gets the car moving. Dual planes build more low rpm torque. Now, the 650 carb is just about right. As for cam shafts, you really need to decide on the heads and gearing first. If you want a couple suggestions, I'd try this cam:
With these heads:
Yes, the vortec heads will work on the older blocks. But they do require self aligning rocker arms-no big deal. Also the stock vortec head is lift limited to somewhere around .460 I think so cam choice is limited or you can have the heads modified or retainers trimmed for clearance. Vortec heads on the older blocks is a very common swap-if you do a vortec search there's a lot of information that's been posted.the heads will bolt up to an older block pre -1980?
