Ok.. so LS1 EFI swap.. has LS1 starter (solenoid on the starter)
here are the highlights...
-Solenoid on starter clicks (once) but wont crank 99% of the time.. 1% of the time it will and cranks strong and fires fast
-Replaced starter, same symptoms
- checked connections and resistance from starter to under the dash by the key (purple wire)
-Key ON =12v
-Voltage at the ignition wire coming off the key switch 12v
-Continuity/resistance good all the way through the purple wire to starter solenoid.
-Jumping the solenoid @ the starter works great
-Purple wire shows only 8.5ish volts coming out of the back of the key switch when cranking.. not sure this is enough to make the solenoid happy, but I do hear it click
What am I missing??
-Key ON =12v
What am I missing??
