Can you explain why Sniper will not work on 11;1 compression?
If I read it correctly he didn't say it "will not work." He meant it's not going to change the type of fuel he needs to run 11.5/1 compression without issues. He said, "EFI won't help."
I have ran exactly 11:1 with Holley Stealth ram with great success but I used a factory 730 ECM and tuned with speed density and no input from an O2 sensor. (I had an Innovate sensor and laptop scanning the air to fuel ratio for months and with great success. I'm now running a Sniper on the same engine and it's also fine.
His solution with a Sniper would be to use the timing control it provides and de-tune the engine. (Cut back on the timing advance) But, he could do that with a carburetor and mechanical or electrical timing controls also. Or, as mentioned, run some e85 and try that.
So, to repeat, he didn't say it will not work. I believe he meant it will not solve his problem.
Or, I misunderstood the whole thing and wanted to say, being able to tune would be the key run running lower octane fuel.
HTH,
Steve
