For you guys running EFI with an inline pump and did not opt for a $700 EFI tank, how are you guys running your fuel return??
First off, submerged or not? I installed a FAST no weld blind hole compression return port on the top corner of the tank but it has no dip tube. Some say it will cause aeration. Some say is just to reduce the sound of splashing fuel and won’t be a problem.
I also believe that the 3/8 fuel line stainless sending unit assembly has a big enough of a blank spot at the top for installing an Earles return return bung with line to the bottom of the tank.
I guess my question is, can I get away with the I UNsubmerged return or go through the trouble of installing the return with dip tube that runs to the bottom of the tank?
Here are some pics of what I have and what I may do based on your advice.
as you can see in the first 3 pics, the universal port does not have a dip tube it’s not possible because it’s a blind instal, like a rivet, and you can’t get to the other side.
on the last pics, that return port with dip tube seems like it can bolt to the blank part of the top of the sending unit. Putting it on the top of the tank is not possible due to there being no room and no way to get your hand / tools in the tank to screw it in. I do t want to do any welding and want to retain my factory eec tank.
by the way, that dirty sending unit pic is not mine. I got that from a YouTube video. My sender and tank are new and clean.
I’m getting everything ready for a Sniper Xflow unit.
