what about clearancing for stroke, ease of fitment, HP ratings looking for feed back??I like the H-beam.
I think they are stronger in the main cap area.
IMO
AL
Not always.:no: Look at Dyers Top Rods and the old tried and true Carillo rods. Both are H-beam's.It seems like the most expensive, lightest, highest h.p. rated rods are I-beams.
The rods I am looking at are pro series I beam and are actually heavier than scat h beams and are supposed to handle 850+ hp 4340 material with 874 arp cap screws 670 grams liteweight version weigh in at 595 g.Not always.:no: Look at Dyers Top Rods and the old tried and true Carillo rods. Both are H-beam's.
On the flip side, 99% of the billet rods are all I-beam designs. Carillo, Lunati, Crower, Oliver, Howards, etc. all make KILLER I-beams.
As to which design is stronger?? I've seen the arguments made on both sides by some pretty sharp engine builders:yes: and the jury is still out.That fact of the matter is unless you are making the kind of power to put you in the top 1%, you'll never need to worry about either.:no: Because at that point you'll be needing to run aluminum rods to try and lengthen the life of the crank.:devil:
As for stroker clearance, that has more to do with the big end design. 99% of the good aftermarket rods are already a "Cap screw" design that is already clearanced for most applications.:yes:
reading this again, Understood what you mean but you meant to say rod cap area AlI like the H-beam.
IMO
AL
yea, that thingy that holds the spacer thing-a-ma-jig!:devil:reading this again, Understood what you mean but you meant to say rod cap area Alrolleyes:
Good point!It seems like the most expensive, lightest, highest h.p. rated rods are I-beams. When it comes to cost/h.p. ratings H-beams are slightly more economical. Weights depend on whose rod and what it's made from; I have some H- beams that are in the mid 500g range, but the light ones (500g or less) are usually I-beams.
Absolutely!!Good point!
I suppose we need to have a budget limit first with the question!:devil:
AL
those are the type rods i am looking at, now is there anybody out there that can post some pictures of the block where it needs to be clearanced during/after the build up?? and of course you get it to fit then get it balanced after grinding and clearancing the rodsAbsolutely!!
There's some good budget rods of both designs out there!!:yes:
Like these...
