Front and rear turn signal lights work. Headlight and tail lights work. But all 4 side marker lights are out and don’t work with signals either. Checked fuses and bulbs. Has a new headlight switch. Any thoughts on a reason before I start chasing every wire. Thanks!
well . . . . . I did have two of my "side lights not working" . Everything else worked (front & rear) . . . .
what my car had = was the small '194 light socket' = one wire in each 'socket' was broken , right where the wire comes out of the 'bulb-socket' . I did change / install new 194 bulbs . . . . when that did - not
work . . . . then, I looked at those light bulb sockets . . better .
I had too replace two of those - - - - been working good since .
(those wires did - NOT look to be broken - - (on a 69 car = 50 years old) - - ) .
later , jim
On my setup I found that the marker lights do work but they are not connected to the turn signal lights. Found a thread on the forum that seems to indicate that side lights became functional turn signals in 1971.
1970 Nova 350/4spd
OK - got ya . . . . . my 69 just "light - up " . . . . . . jim
