Hey guys, I'm looking for advice on this. I bought my 75 back in 2014 and decided to put junkyard vortec heads and a new cam in it, I went through the break in for the cam and everything ran fine for about 200ish miles. then I started having trouble getting it to run and everytime I would adjust my carb to get it to run, the next day I would have to adjust the carb again to get it to run so I got a new one and it ran but had an erratic idle so I resealed the intake and put the fitech 400 on it and that went away. Then around maybe 300? Miles it started shooting coolant from the radiator cap but only when I was driving around and not at idle or if I revved it, so I replaced the cap twice with no luck. I burped it a couple times and it still wont stop. And everything I've read says it's a head gasket so i pulled the passenger side head and found orange stuff almost like calcium buildup all over the inside of the intake and head but the coolant came out clean. It wasnt there when I pulled the old heads.
My biggest questions are what is this orange stuff and can it be cleaned out of the block? Is it worth getting the heads surfaced or should I just replace them? And do you guys think this could be a bad motor or mostly caused by my lack of experience and having only put 300 miles on it in 5 years?
The first pic is where I think air could have been getting into the cooling system but I'm not sure
