Here are the pics I took of the block when I went to look at it. What do you guys think? The guy said he has to get $200.00 for it. He took a hone to one of the cylinders that you can clearly see in the photos, he said it's been sitting under his work bench for quite some time and is currently standard bore. It has light surface rust and of course plenty of dirt and dried grease. The casting number is 361959 which indicates it's out of a 73-75 Chevelle and was an actual 454 CID. I plan to have Nyes Automotive in Muncie, IN work it out to a 496. Do you think I should jump on this for $200?
In this pic you can see the one cylinder that he honed out:
The honed cylinder:
This is what most of the other cylinders look like:
This is the worst cylinder:
Rear end of the block:
Oil Filter adapter area:
Casting Number "361959":
Mains / cylinders:
Another shot of the mains and cylinders:
Yet another:
One last showing the honed cylinder and all others:
Lifter valley:
The honed cylinder:
Mains / cylinders:
Yet another:
Lifter valley:
