critical speed of driveshaft depends on length, diameter and RPM? Geeze, I just need a driveshaft. I have visited Mark Williams, Strange, Denny's, and Inland Empire. I had no idea a 500~600 dollar driveshaft was required. I knew some things about 1350 joints and forged pinion and trans yolks. The stock shaft is 2 3/4" diam. or there abouts and rated critical speed of 4,000 RPM. In high gear at the big end I'm @ 7300 RPM. Seems to me (T/C slipage excluded) the shaft RPM would be the same as engine RPM.
At this RPM they have me into a 3 1/2" 4130 tube with 4130 weld yolks and they can't build it without a trans yolk. (they need it to balance) So the trans yolk to match everything else is of course 179.85 extra.
This is a big hit and I did not see it coming.
