I have a 69 so I'm not sure but if the set up wasn't changed throughout the years I think thats the way to do it...from below upanybody ?? I tried to punch out the pin but no luck .
It seems to me that you are referring to the arm on the column under the hood, is that right?Anyone ever removed the shifter Arm off a 63 Auto .? I have switched to a floor shift and want to take the column arm off .
I have, are you still removing yours?Anyone ever removed the shifter Arm off a 63 Auto .? I have switched to a floor shift and want to take the column arm off .
Its just a pin and takes a punch from the bottom to remove it. Try soaking with a penetrating oil first and let it set for a bit. It is knurled at the top and try soaking there.Anyone ever removed the shifter Arm off a 63 Auto .? I have switched to a floor shift and want to take the column arm off .
