Usually an indication of a bad ground and not with the shift light. If it is grounded near the dash, check all of your dash grounds. Try moving the gound directly to the battery and see if it goes away.
It could also be the 6AL isn't grounded well enough and it is feeding back through the shift light circuit. Try grounding the MSD box directly to the battery as well.
