Hello,
I have a problem that I can't put my finger on, When I am setting out in first gear the entire car will shake while I'm pulling out the clutch. It only does it when coming out a full stop. If it's a rolling stop it doesn't do it, or do it when changing gear. Any ideas what this is?
Just to clarify Nova Thug's clutch chatter: Overheated spots on the flywheel/pressure plate can cause uneven friction of the clutch/flywheel surfaces and the clutch will grab/slip/grab/slip as the clutch is actuated. Most times this can be corrected by replacing the clutch/pressure plate and resurfacing or replacing the flywheel.
Assuming you’re running a stock-style, organic clutch disc. Metallic puck style clutches are going to chatter, along with taking out everything downstream 🙄
