1 - 3 of 3 Posts
I won a High Volume sealed power big block oil pump off of ebay. I pulled the pump cover off and found the good billet gears and I think it's old stock from the 80's or early 90's. Is this a relabeled melling pump? Looks of good quality and doesn't have the PM gears so I might run it in my solid roller 468 motor-what do you think.
Does it have a M77 cast into it?
If it is a Melling pump, it could have been manufactured to specs for Sealed power.
Odds are it is a Melling.
If it's a older unit, the casting around the mounting area will be larger.
Sounds like a great find!
Al
It has sealed power casting numbers on it and there isn't the M77 anywhere. I don't have the pump in front of me now.
1 - 3 of 3 Posts
