What should I use between my radiator and fan shroud to fill the gap? Thanks, Jumm
I don't use anything and I don't think they came with anything in the gap. It's just not that wide. If you wanted to seal it up I'd use a foam seal like you might use on a storm window or door. RM
Thanks, If I dont hear from anyone else with something better thats what Ill use. Thanks again, Jumm
I used weatherstrip I bought at Lowe's. It was about 3/4 wide and 1/2 thick; it filled the gap really well and I could tell a difference after filling in the gap. I checked the difference with a piece of carboard on the radiator. Before the cardbard would slide and after it was stuck tight to the radiator when running.
