I have a '69, which was an inline6 swapped out with a sbc350. After the swap the shop had issues getting the alternator and power steering pump to fit. So I assume I need a bracket for a low mount alternator and another bracket for the power steering.
I've seen a ton of brackets for either short water pumps or passenger side alternator but I have a long pump and driver side alt. Can anyone suggest a bracket that will take care of mounting the power steering and alternator mounting?
Thanks!
I've only seen drivers side alt with short pump. My 72 had a long pump and the alt on the pass side. I switched to a short pump and moved the alt to the drivers side so my new a/c compressor would be on the pass side so the hoses wouldn't cross over the engine. I also had to buy a new p/s pump bracket that mounted it low on drivers side, below alt.https://www.stevesnovasite.com/forums/attachment.php?attachmentid=356565&stc=1&d=1541951642
What about the March sport serpentine system?
I have this on my 67.
