I've got a 355 fresh from the machine shop, got it all together and doing the initial oiling with a drill today, while running the drill the pressure was 50psi at the gallery in the top rear of the block. Problem is there was no oil coming out of the rockers. The crank was set at tdc #1, I rotated the crank 180 degrees to see if that would help and it didn't.
Any ideas?
The motor is from my 85 Suburban and the bottom end including the timing set was put together by a reputable builder...
Any ideas?
