1 - 2 of 2 Posts
Just wandering.... what type of gaskets most of you are running with the Sanderson CC-14 Headers on First Gen's? Sanderson says to use only a silicone bead around each tube but if I use that I will have a hard time getting the headers between the fenderwells and heads without scraping it all off. I have installed the headers with Mr. Gasket Copper gaskets and they are leaking/ticking. Ideas or examples...........THANKS!
when you run a copper gasket your soposed to retorque them 2-3 times. not sure if you did this but in the past my header bolts would back out and blow a gasket. i dont use the copper ones but after buying header locks for the bolts i dont have that problem anymore.
1 - 2 of 2 Posts
