I purchased a serpentine belt system. Complete system, including A/C compressor, alternator etc...
I also have a Vintage Air A/C system and plans to install it all (obviously).
But, I would like to run the serpentine system while I wait to install the A/C system.
Can I run the system, with the Sanden compressor installed, but not wired up electrically nor connected up to A/C system?
Do I need to cap off the hose connectors to do so?
I assume the clutch will not engage as long as it's not connected up electrically.
Thanks in advance for your thoughts.
Mike
Thanks.. that was my thoughts. I was hoping I could find a bypass pulley with the proper mounting to take the place of the compressor but haven't found one yet.
Mike
I had also sent an email to Vintage Air. They responded back with yes, I can run it no problem as long as the wire is not connected.
Mike
I had the Commpressor mounted about 5 months before wiring and charging the system. I wanted to get some test miles on the car after the build.
