i have a hydraulic flat tappet cam in my car now...if i wanted to switch to a fuller roller setup would any modifications have to be done to the block to use a roller cam...
What's a "fuller" roller? Did you mean "full" roller? Is that different than a partial roller? You either have a roller cam, or you don't--there is no in between.if i wanted to switch to a fuller roller setup
That would depend on the cam core.:yes:don't forgot a brass distributor gear
i think his motor is together though ...... i beleive he is just doing a cam swap ....... at least thats what it sounds like to meIf you're just wanting to spend money on your cam, then you can go the extra 'roller' mile.. and get roller bearings installed instead of the standard cam bearings. this requires the block cam journals be machined out to accept the roller bearings.
I understand the price of the roller bearings is cheap, compared to the machine bill.
No block modifications needed.i have a hydraulic flat tappet cam in my car now...if i wanted to switch to a fuller roller setup would any modifications have to be done to the block to use a roller cam...
