does anyone know if the comp cams sbc 1.52 7/16 ultra pro magnums will clear a 1.56 spring the techs at comp dont know ive talked to 3 of them
Doe's not matter,
1604-16 7/16" 1.52
Is not available yet.
FYI
AL
the ultras do not clear the trunnion touches the springs, does anyone have a suggestions sbc 215 dart pro 1s 2.08 1.60 .150 longer valves having problems with the rockers having enough clearancebetween the spring and trunnion thanks
A picture might help us better understand the problem. I had what I think is a similar issue with my 565 and I installed a lash cap and longer pushrods which helped me get clearance but I have T&D rocker stands and I had to shim them up too. I only had problem on my int rockers.
If it's .150 longer valve stems then you will need that much longer pushrod, but you should still verify pushrod length first.
I have seen aluminum roller rocker arms ground down so as not to hit the retainer, but wouldn't do it unless I had to.
