lift
The lift you have takes into the rocker ratio, .340 cam lobe lift X 1.5 rocker = .510 at the valve. you should have the clearence checked between the retainer and valve seal , as well as the spring setting at the maximum lift for ciol bind.
· Premium Member
Hey whats up guys! lets say my heads have a max lift of .540 and im using a cam that has .507 and .510 lift if I'm using 1.5 roller rockers am I going to have a problem?
507=338 at the lobe
510=340 at the lobe
338 x 1.6= 540.8
340 x 1.6= 544
they do have 1.52 and 1.55 ratio rockers from differant company's.
Al
