1 - 2 of 2 Posts
Just got the CPP front disc conversion been working to get it done (slowly)
the last part before final, is the brake hose any tips or problems solved that will help and make it less stressful! so any help to ease the pain is needed!
Rich
For some reason this part ( brake hose) becomes close to impossible to remove.
I have heard too many stories of guys destroying the hose and even the brass fitting trying to pull these.
I even had a brake shop refuse to do mine in a 89 Monte Carlo.
If you are going to try I would saturate it over night with PBS Blaster.
If you are putting all new brake lines and fittings just carefully retrace your path an be sure to install the brass fitting with the right tools.
There are also good general books on this.
Good Luck
1 - 2 of 2 Posts
