I need help on this (no response on 4th Gen Forum):
Can anyone tell me what type of replacement belts you used in your 4th Gen or any 3rd Gen?
Can any universal 3rd Generation style fit?
We were looking for something that will bolt in to the original mounts, knowing the shoulder belt might not be retractable.
It seems the "universal" type will require bolting a "hanger" into the "B" pillar bypassing the original shoulder belt mounts?
Any suggestions on a manufacturer?
And what is the best way to remove/re-install the current belt mounting bolts?
Any help is appreciated. THANKS !!
I'm in the same situation as you on my 69. I'm thinking of just buying Black Universal Lap Belts from a local upholstery store for $16.99 ea.. They sell them in two different lengths, I plan on using the orginal bolts to mount them. Then Dying the shoulder belts black and hanging them up in the holders for the original look.
Rod
Try Morris Classic Concepts.
I agree. Morris Classic Concepts have a quality 3 point retractable belt system that uses all the factory mounting bosses. If you a search on "3 point seatbelts" you'll find loads of discussions about this subject.
