I don't know if there is a quick way :( . I hope to never have to take another one out nor put them back in. I found it to be no fun at all.
Take the widow stop out should be a 7/16 hex head with a little metal tab under it. roll the window all the way down, take the phillips head screw out of the outside (or inside) i guess on the top of the vent window, then take off the nut at the bottom of the widow track connected to the vent window take the phillips head screw out of door it's a long one take vent window out first. You will have to twist it to get it out but it will go without damage. take your time after the vent window is out you will figure out how to get the door glass out,, Timmy
