well after getting my nova about 3 weeks ago i started to work on it today and to be stoped in the frist 5mins.im tring to find and fix oil leaks and way i was looking and they broke the dipstick tune off in the block and silconed it back togather.well i want to fix it right so i have a working dipstick but the bass of the tube is broke off in the block i tried to get it out from up top but i dont see any way so how do i get it out of inside the motor? i really dont want to pull the motor but i need this fixxed so how do i go abou it thanks
It will not fall in, the hole is tapered.
You have 2 choices. IMO! :rolleyes:
A easy out. Our a extractor.
Or you can take a small punch, and try collapsing the tube, then pull it out with some needle nose pliers.
Al
I used a drill bit to get mine out when i broke it off...worked like a charm
I DID NOT drill it out! I walked out the remaining piece of the tube!
I just pored A LOT of oil through it after i finished (just incase i got metal shavings in there)
