Building my own caltracs down to needing the leaf spring eye bushing deminsion so i can make new ones out of aluminum.
Does anyone know this
Banned
make it easy on yourself... call Calvert Racing and ask for the bushing dimensions. it is a press fit so measuring the spring eye won't give you the proper answer. when i pressed in the bushings in my leafs i noted the eye opens quite a bit so i can tell you it's not a normal "interference" press...
Phone:
(661) 728-9600
Fax:
(661) 728-9615
Email:
[email protected]
[email protected]
Mailing Address:
4530 Runway Drive
Lancaster, CA 93536
Banned
why not? you don't have to tell them you're building your own...
i still have the aluminum bushings installed on my '64... even after i removed the Cal-tracs. it'd probably be impossible for me to measure as i have non-factory front spring pockets... hopefully someone will be able to assist you.
D'OH! i just remembered... send a PM to Jim/1qwikss, he's made a couple sets and may have the dimension...
http://www.stevesnovasite.com/forums/member.php?u=1235
