1 - 3 of 3 Posts
does anybody make the rear roof pillar where it connect to the quarter panel.mine is rusted right where it connects to the quarter.where would i go to find this or am i out of luck trying.
Attach some photos of the damage, maybe someone will have a good idea. I think you have a 65?, these first gens usually need some help in the front end and braking department also.
We had the same problem on a 63. I could not find replacements so had to make our own. Here is a before and "during the work" shots once we got the patch fitted, TIG welded in, ground down, and epoxy primered. We then performed minimal body wok to dial in the diagonal pillar line, topcoated with primer, and painted the pillar. I don't have a finished photo, but we were very happy with the results. That was three years ago. Whatever you do, treat the metal inside with ospho and coat with POR15 once you have it opened so rust doesn't happen again.Hope this helps.
420500
420501
1 - 3 of 3 Posts
