I just finished the install of a TKO600 in my '72 and took the car out for a shakedown yesterday. This morning I noticed a small puddle of oil right under the back of the pan. I'm guessing the rear main is leaking again.
My question is, with a steel Quicktime bellhousing that has the full block plate behind the flywheel, is it still likely that the oil will contaminate the clutch or can I wait a couple months before pulling it all out again.
I think I already know the answer :(
What kind of oil? If I run synthetic oil in my 1973 block...it almost runs out the back. Puddles oil. I changed back to Valvoline and puddles are gone.
Dave
lol, Royal Purple.
It leaked years ago and I replaced the rear main and every other gasket while I had it out.
I don't really want to attempt to change the seal with the engine in the car, but my buddy offered to let me use his lift to give it a shot. The TKO is tight in the trans tunnel so I doubt I'd be able to lift the engine much to get enough clearance to pull the pan.
I moved the car today to see if it keeps dripping or not after I cleaned the pan up as much as possible. Hoping to see some drip trails...
