1 - 2 of 2 Posts
I have a 72 Nova that has 3.08 gears in the rear end. It also has had a spool installed. I have a 307 engine with a TH350 tranny. Is this rear end good for the car? I hope to eventually drop a 383 stroker with a TH400 tranny, so what gears should I run then? Thanks for the help.
What gear ratio or what rear end components? Regardless, what are you looking to do with the car? If you want just an 1/8th mile warrior, your ratio will be drastically different than a 1/4 mile racer or a street/strip that will see highway use.
1 - 2 of 2 Posts
