1 - 3 of 3 Posts
Hey guys, I think that I have a stock 10 bolt rear end, with stock gearing. I want to change it out with something else. I have read that I want a 12 bolt rear-end with posi. Where can I find a 12 bolt, or what type of car can I get one out of. Oh yeah, I have a 1978 nova with a 350 motor and trans. I appreciate all the help.
rearend for a nova
Yeah, I have a 12 bolt under my 72 nova 4:11 been real happy with it. It has a mono-leaf spring with one helper spring in it. I have had the rearend for about 4 yrs not a lick of problems. the rearend orginally came out of a 72 chevelle. I just welded spring perches onto the rearend in the locations that I needed to fit under my nova. Works great. Anyway I would tell u that a 9 inch ford is better. Just because of the outer bearings are stronger for a lot of horsepower. U can modify the 12 bolt by using C-clip eliminators. it basically makes a 12 bolt like a 9 inch ford. But, I have about 450 horse going to the real wheels. Have not had any problems even with drag slicks. I am thinking about selling this rearend to go to another project. But, anyway just wanted to responed to your question
see ten bolts are desent just depend if you have to 8.5 or 7.5
http://www.novaresource.org/axle.htm
heres how you tell
8.5 is the better 7.5 are weak
I put 4.10s a eaton posi and moser axels in my ten bolt it will handel alot of power. 4.10s pull good with my low horse engine
1 - 3 of 3 Posts
