I know that this subject has been covered but I have a rear end that doesn't match date codes shown on Novaresource web site. I just got what appears to be a 1978 Nova 10 Bolt. The Axle tube stamping is: 2TX G 80472. The 2TX decodes to 1978 Nova 3.08:1 Open; G is Detroit Gear; 8047 is not defined on any Nova web site - I assume that it is 8 for 1978 and 047 for the 47th day of that year (Feb 16); the 2 should mean second shift.
The casting # is 1254333, with a casting date of B 15 8. My question is: Has anyone else seen rear ends with similar date coding? Is there a web site that can confirm my interpretation?
By the way the spring perch centerline is 42.5" and the overall dimension is 60.25" so it sure seems to be a 70's Nova rear.
When opened up it has 3.42:1 gears with an Eaton Posi that had to be installed after Feb 1981 based on the date code on the ring gear. Not a bad buy for $100.
Since the casting date and assembly date are within a day, I would say your are correct.
Rearend ID
Please post some pictures and will ID the rear. Need the shot of the rear cover area with the outer casting included around the cover.
Or sent it to www.jdrace.com and we can I D it there too if you have trouble posting pictures here.
10 Bolt Info
I can post some pix tomorrow. It looks exactly like your web site 10 Bolt 8.5" leftmost picture. It is a 8.5" 10 Bolt with an Eaton Posi now.
Have you seen those kind of date codes before with the additional digit being the year?
