How do you get the back of the rear bench out of a 70 Nova? I have the bottom out. and see you can pull the bottom of the back out. tried to lift it out and it will not move. Sounds like it is hitting something
Is there a trick?
I found this
https://www.stevesnovasite.com/forums/showthread.php?t=542481
Do I need to pull the bottom out then lift the top? Looks like just some big hooks at the top that are hitting part of the spring frame.
I struggled with getting mine out this past summer. You are correct the trick to getting the back out is to bend the metal tabs out at the bottom and pull forward to release that part of the back, then lift up so that the release the top from the hooks.
Bottom:
Push the center of the frame on the bottom rearward, and then upward, to release from hooks.
Slide whole bottom section forward, and out.
Top:
Remove screw(s)/bolt(s) exposed after bottom section was removed.
Lift seat upward to release from hooks/tabs.
Pull forward, once clear.
