Ok let me start by saying I've been working on cars for a long time, I grew up on Chevy's of the 60's when they weren't very old :sleep:
yeah I know
So I'm some kind of special idiot, I can't figure out how to remove the radio antenna :rolleyes:
I remove the nut, I assume the antenna should maybe drop a little and the little feet rotate so I can remove the antenna straight up
no deal, the antenna won't drop enough, won't even go down 1/8 of an inch!
So is it me or is there something inside I can't see or is maybe something in the way that shouldn't be there?
This is a non-telescoping antenna, won't get shorter than about 20 inches or so
All help is appreciated
all sarcasm will be accepted and graded
thanks :beer:
Have you tried a BFH?:devil: Never fails me.
Ive never had an antenna on my 64, but your telling me the whip doesnt unscrew from the base?
In that case, a BFS. (Saw) :D
sorry.......................wagon
it's in the cowl which is inside the car right?
can I access it by removing the glovebox?
Do I have to remove the heater to get the kick panel out? It doesn't seem to want to squeeze out that way.
On a '65 you will indeed need to at least "move" the heater accordingly in order to remove the plastic passenger kick panel/vent assembly.......:yes:
