Ok great, thank you. Do you also happen to know what size those 2 ports are on the entropy rad? Im gunna plug top one and use the lower one for my -4AN steam vent
The port under the upper hose is 1/4" npt. The two on the drivers side are for a trans cooler. I wouldn't use the lower one for the steam vent. It really should be at the highest part of the return, which is the upper hose, or water pump discharge, as that is the water coming out of the engine. I believe it gives you the best aggregate temperature of the engine.
Tom, curious why you are running temp gauge from the hose? Inline i assume? Im running factory lsx location from the cylinder head. N if i wasnt, id thought id use 1 of 2 ports on entropy radiator for it. Other being for the steam vent. Just curious is all.
Yes...inline. As I said above, it is the water coming out of the engine. I feel it represents the best actual engine temp, as the sender in the head can read as much as 30 degrees higher. I'm sure the OE's use this as a temperature go-by for fueling strategy, but I never cared for one there, as it is subject to latent engine/header heat....just my opinion....
Some LS folks say to put the temp sensor in the top of the water pump. I had it in the head like the factory and then drilled the boss on top of the water pump. The head would read so high that it scared me. The water pump was more even and I felt more accurate for the system.
Some folks do put it there. I don't care for it for a couple of reasons. On the remote chance that you lose a water pump, especially on the road, you have no place to put the steam vent.....
Also, upon replacement, you may not get your core money back with a hole in the pump. In the chance that they may weld the hole up on a rebuild and resell it, you might not be happy to get a replacement pump with a plug in it, or welded up.....again, just my preference.
T,
