Does anyone know offhand if a '64 radiator will mount into a '63 without (much) 'massaging'.
I think all of the early Nova (62-67) radiators have the same mounting points and dimensions. All of the Nova parts vendors list the 62-67 rads as the same part number.
I'd guess that you'll have no problems dropping a 64 rad in a 63.
If the 63 is a 6 and the 64 radiator is from a V8, there may be a clearance issue due to core thickness.
v-8 or 6
The mounting is the same for all years though 67 but the V-8's used a spacer that would be needed to get the radiator close enough to the fan for it to work(unless heavy duty radiator with a cowl). Also I believe some years used a different upper hose connections but you can usually work around that.
